JHPIV »
https://forums.nicoclub.com/jhpiv-u48033.html
Fri Nov 03, 2006 1:38 pm
Ok, I'm confused...the sticker on the driver's door post advises cold pressure set at 30psi on my '05 Sedan. I've had the low pressure warning come on once, (on my drive home from the dealer), and noted one tire was reading about 24psi. I brought all tires up to 30psi and have been keeping them at that pressure. Tires are stock size. Tire wear seems to be even, but I've only put about 3,000 miles on the car since I picked it up, (1,700 of that was the drive home from the dealership!) Should I kick them up to 35psi? Thanks.
