hum........no I don't think so
http://nicoclub.com/zerothread?id=273&h ... =IAA+valve
try the link there and look under IAA valve....the picture of the screw is viewd from the firewall. If you look go on the passenger side of the car and look behind the intake manifold....8" from the firewall you will see it.
I believe this is what you do.You let your car idle and disconnect your TPS valve connector (above your throttle body closest to you) there are two big connectors the one closest to you is the one. adjust the screw...I forget which way increases the idle. when your done adjusting...turn off the engine. connect TPS sensor back and turn back on.
if you ever get the timing gun......point it at your crank pulley and notice there should be a nail. that should be pointing at the 20 degree mark (mark furthest right). if your left of that mark your running to lean. too much to the right than your running rich. each mark indicates 5 degrees.
try 240sx.org and go to the faq's section it has a write up.
Hope this helps.
