nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Sun Aug 23, 2015 7:24 pm
Sorry to hear about that, bum bearings are never fun.
Dont just install a new bearing withing grinding the crank, it will start knocking in a couple thousand miles, if your lucky.
If you have a bad bearing and compression on one side, either rebuild, or find a lower mileage engine, or one that is running. Another thing that could cause low compression in the one side is the timing belt skipped a tooth or two.
Personally, I would rebuild the engine. It will cost around 2k to properly do it. If you want to chance it, get a used engine, looking around 500. I have had really good luck on used engines, but these are cars I am selling and not keeping. If I am keeping the car, I will rebuild. This way you know it is good to go. If it does fail, only person to blame is you.
