Low compression (120psi cly.2,4,6) 150psi cly.1,3,5
Rt300zxtt
Car: 1990 300zx type pearl white manual
Does anyone know why? I checked the oil and it's fine no milky look. Also did a wet compression test on cly.2,4,6 and it read 130psi, I'm not sure where my problem is. Any suggestions, thank you in advance.
Reason: Moved to correct forum
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Check timing belt first before tearing the engine apart. One bank(side ) showing low comp is also a sign that it may have skipped a tooth on the timing belt. Remove covers and count the number of cogs between each cam position. The FSM has a nice diagram showing the required numbers.
DCaff300ZX
Car: .
1993 CRP TT- Modified
^^^^This, and the fsm is your best friend for figuring out issues with our cantankerous beasts.
