cullenj76 »
https://forums.nicoclub.com/cullenj76-u10393.html
Mon Apr 18, 2005 7:55 am
A lightweight aftermarket crankshaft pulley is NOT the modification you want to save some money on, by purchasing a product with no reputation or postive customer experience. A off-brand muffler...off-brand strut-tower brace...that's ok, but not a UDP. I highly recommend an Unorthodox Racing or a Definitive Motor Sports UDP.
As for the install on the auto... You can remover/install the pulley by using a large breaker bar. Rest the breaker bar against the lower control arm. That will give you leverage. Hop in the car and blip the engine (as if you were going to start it up, but do not allow all cylinders to fire to the point to where the motor actually starts). The breaker bar will use the control arm as leverage and the crankshaft will turn, breaking the nut on the UDP loose. Let the engine do the work for you.
