Losing power...
tegraracer90
Hello, I have a 1994 Nissan Sentra, within 1-2 years of buying the vehicle brand new the fuel pump went out...we took it back to the dealer and it was replaced. 3 years later it burned up again. This time it was replaced by my father in our garage. Then again 4 years after that it left my father along side the highway again. By now we knew something was terribly wrong. So instead of replacing the fuel pump with a Bosch pump...we replaced it with an OEM, and replaced the fuel vent cap, and the fuel pressure regulator. The so far has run true...although it doesnt have any power at all...and gets horrible fuel milage....anyone know whats wrong?
Presscott707
Car: 1999 Maxima 5spd
is there a cel on.
tegraracer90
what is a cel?
SE-R GUY
Car: nissan sentra SE-R
CHECK ENGINE LIGHT
nametakennow
Car: '06 MINI Cooper S
The light is amber in color and says Service Engine Soon.
This is an OBDI vehicle, so the diagnostic codes from the ECU (which trigger the light) are going to be relatively general.
It sounds like you just have a lemon. Have the fuel injectors been replaced or at least cleaned in this time?
tegraracer90
nope no check engline light......and the only thing that has been done is that cheap fuel injector cleaner **** you put in the gas tank
