VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sat May 07, 2022 5:26 am
The only things that generally make noises like that are bearings, and possibly the Torque Converter. If it's "buzzy" you can add the timing chain guides to the list. Since the water pump on the 3.5 is chain-driven, you can eliminate anything on the belt by removing it and briefly driving the car. If the noise disappears then you know the source is something on the belt, P/S, alternator, A/C clutch or one of the idlers. If not, worn guides or a bad water pump should be audible with a stethoscope on the front cover even if you can't hear it at idle with naked ears. Same thing for the Torque Converter, you should be able to hear it with a steth on the bellhousing (although you'll need an assistant to put the car in gear with the brake on).
