Loose clamp question
digimon
Car: Nissan Rogue 2012 SV
Hello,
I noticed jingling when I started the car and found something that looks like a loose duct clamp on the exhaust pipe.
Any ideas what this clamp is for and how to fix?
Thanks!
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
That isn't OE, but we often use stainless band clamps like those to silence noises from broken tack welds on the OE heat shields. I'd give the exhaust system an eyeball, chances are you'll find something loose which that clamp was holding down.
digimon
VStar650CL wrote:
Thu Sep 22, 2022 11:03 am
Could be holding the heat shield in place?
Will something else go bad because of a missing heat shield?
Thanks!
VStar650CL
Technical Expert
No, but the shields that are tack-welded to the pipe can make some of the most irritating bumblebee and tincan noises imaginable. If that clamp was applied to remedy a broken weld, you should probably locate the spot and tighten it back up.
digimon
VStar650CL wrote:
Thu Sep 22, 2022 11:37 am
I will see what I can do, but it is possible that the heat shield is long gone...
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
No one on the internet is going to be able to tell you that with the picture you posted. But I guess its possible.
Get under there and look yourself or take a picture while under there for us to look at. Then we can comment.
digimon
itsa300zx wrote:
Thu Sep 22, 2022 1:56 pm
I attached another picture.
Hope this helps.
VStar650CL
Technical Expert
There are no shields on that section of pipe, but there is supposed to be an intermediate rubber hanger in between where the clamp is and the main muffer at the rear. Maybe somebody tried to use the clamp as a kluge substitute for the hanger?
digimon
VStar650CL wrote:
Fri Sep 23, 2022 6:06 am
I found a youtube video that shows the exact same duct clamp at the same location, that makes me think that this can actually be a factory installed part (see attached picture)?
VStar650CL
Technical Expert
That's a rusty heat shield being clamped to the pipe. Weird, the parts drawings usually show the shields when present, but I guess it has one there after all. Anyway, that's a repair, it is not OE. Nissan doesn't use that style of band clamp for anything except intake boots.
digimon
VStar650CL wrote:
Fri Sep 23, 2022 8:21 am
Thank you for your response.
So, a duct clamp appears on more than one car to hold a heat shield, that is not supposed to be there per Nissan drawings...
I wonder what else Nissan left out of drawings :)
VStar650CL
Technical Expert
Everybody uses band clamps to fix busted tack welds on heat shields, and busted tack welds are almost inevitable on anything more than about 8 years old. There's nothing unusual about that. The wife's '13 Altie has two of them on the flex pipe shields, along with probably 75% of the older Nissans on the road.
itsa300zx
2011 Nissan Rogue S
2008 Highlander SR5
I used the same fix for my rattles in my 2011 Rogue.
digimon
VStar650CL wrote:
Fri Sep 23, 2022 10:04 am
I understand, but I own this car since its birth, and I don't think a service technician would add a clamp without telling me about that.
It is possible, of course, that I was told, but forgot about it.
Thanks everyone for chiming in.
VStar650CL
Technical Expert
digimon wrote:
Fri Sep 23, 2022 1:25 pm
If that's what you think, please read this Nissan bulletin and check out what the "fix" is. Mind you, this is recommended by Nissan. Your repair order would read something like, "Performed repair per bulletin NTB14-018," with no mention of a clamp except as a part number (if it was warranty) or a shop expense:
https://static.nhtsa.gov/odi/tsbs/2014/ ... 5-9999.pdf
digimon
VStar650CL wrote:
Fri Sep 23, 2022 2:27 pm
This makes sense now. Thank you!
digimon
Eventually, on the next oil change I was handed the rusted heat shield and broken clamp.
On my question if we need to mount the heat shield back, the answer was negative...
VStar650CL
Technical Expert
That far back in the system, I agree, the shield is probably just keeping a little heat off the diff and you can live without it. Just as well, because once the welds are all broken at both ends, they're usually unsalvageable.
digimon
A jingling noise when the engine starts is back. It goes away after a minute or two.
Since the heat shield and clamp were removed, as I mentioned earlier in this thread, I suppose the exhaust pipe or muffler is loose now?
What else could jingle for a minutes when engine starts?
VStar650CL
Technical Expert
If it only happens at startup, you may have a noisy alternator clutch. The clutch is an overrunning type and they make all sorts of metallic noises when the guts get loosey-goosey. There are also a bunch of heat shields further forward on both cats and the flex pipe.
Return to “Rogue Forum”
