Looking to spend $800 on my spec v any ideas?
1gr8v
Car: 2002 sentra se-r spec v
I recently bought a 2002 sentra spec v. I'd like to make some upgrades but don't know where to start. If you have any ideas please let me know.
Catback exhaust.
http://www.brmexhaust.com, one of the nicest setups for a B15 you'll find.
nametakennow
Car: '06 MINI Cooper S
If it doesn't have a header, get one before the precat blows up. Loctite the butterfly screws too.
Once that's done, pick up an exhaust or intake (or both).
I personally haven't heard a better sounding exhaust than BRM's, but it kind of depends on what sort of sound you want. If you like it low and mellow, BRM is the way to go, IMO.
No, I'm not saying that to suck up. I like Stromungs and Thermals, I even like Greddy and I've heard some custom setups that sound nice too, but all of them were too buzzy to me to listen to every day.
wperdigon
Car: 2003 Nissan Sentra SE-R Spec V
Hey whats going on - what are your current modifications? I saw the new wrp technology angled intake manifold spacer in the new new magazine of nissan sport and yielded really good gains and it's only 230 bucks iirc- i would look into finding one of those for your car -
william
1gr8v
sounds like a good idea... my engine blew a week after i posted this though. but where can i get a hold of one of these spacers?
VMPhil
Car: 2007 Volkswagen GTI
WTF mate howd that happen?
Twilight sentra tuner
Car: 00' Sentra Gxe
yeah dude. what in the hell did u do to it?????
nametakennow
Probably ate the precat.
1gr8v
well i drove to work one day and my car started clicking. I checked the oil after work and there was no oil on the dipstick. So i had someone drive me to get oil and put 2 quarts in. When i started it, it ran fine so i started driving it home. Then the same noise came back and it died. I had to get it towed to a shop and they said the oil wasn't draining to the bottom of the engine so it fried.
nametakennow
Yep, your car ate its pre-catalytic converter. Nissan owes you an engine.
Or it ate a butterfly screw, in which case Nissan still owes you an engine.
SE-R GUY
Car: nissan sentra SE-R
HOW IN THE HELL WOULD IT EAT THE PRECAT?
dxtreamsktrxc
Car: 2002 nissan ser spec v
how did the car eat a butterfly screw or the precat? lemme know asap my gf got an ser spec v i hope this doesnt happen to her car!
SE-R GUY
THE BUTTERFLY SCREW COMES LOOSE FROM AGRESSIVE DRIVING.IT CAN BE AVOIDED BY LOCKTITING (SP) THEM.
SE-R GUY
OH AND FOR THE PRECAT. The QR25DE tends to run a fairly rich air/fuel mixture so it is very likely that not all fuel is being combusted in the cylinders and instead combusted in the precat, which can cause it to break apart into small pieces. These substrate pieces get sucked back into the cylinder and damage the cylinder walls.
I COPYED IT FROM SOMEOTHER POST
VMPhil
yeah there are like stickys above and its all over other sentra forums. Precat and Butterfly screws are QR BANE
nametakennow
The butterfly issue isn't purely the result of aggressive driving. It can just happen.
The precat disintegrates and parts of it get sucked in back through the exhaust valves. The screws come loose over time because the butterfly was designed poorly and they can be sucked in via the intake manifold.
SpecV2C
Car: 03 Nissan Sentra SE-R Spec V
Its amazing what you can find out about a car if you just do some research and yeah Nissan owes you a motor
1gr8v
There's no warranty i got the car from a general motors dealership with 93000 miles... any one know where to get used engines in minnesota? Are there any other options for engines?
SpecV2C
You dont need a warranty..its called a recall...Nissan owes you a motor...take it to any nissan dealership and tell them you want a new motor
wperdigon
SpecV2C wrote:You dont need a warranty..its called a recall...Nissan owes you a motor...take it to any nissan dealership and tell them you want a new motor
Incorrect - there was no recall for the catalyst itself, just a recall to place a heat shield behind the catalyst so that in event of a failure it would prevent the motor from catching fire when a rod would get thrown the the block -
you may have a better angle if the motor swallowed a butterfly screw and that caused the failure. There was a recall for that in the 2002-2004 years and it would still be a strech though.
If you need a motor, let me know. I live in DE but I have a brand new zero mile engine and I would need your motor back, but we can work something out -
also on the spacer that I mentioned earlier, email [email protected] for one - they have them in stock now -
If you would like to talk about getting a motor - shoot me an email, i'm not on here very much - [email protected] is my email -
thanks, william
SpecV2C
Wasup will. Thanks for callin me out like that....makin it look like i dont know what im talk in bout its all good though man.
