MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Mon Jul 07, 2008 2:28 am
I'm not sure on the rear end ratio, but the full engine code for the S/C motor is VG33ER. The "R" denotes the supercharger. It's a single overhead cam 12 valve V6. Info on the VG33E and VG30E (the normally aspirated variants of the motor) will generally apply to your motor as well.Just in case you're not familiar with Nissan engine designations, VG is the engine "family", the numbers are obviously the displacement, and the "E" indicates electronic fuel injection.
I believe (but am not 100% sure) that timing belt replacement interval on the later truck VGs was 90k miles.
The VG's a reliable motor, if a bit on the short side of power in stock form. As long as you keep the oil changed on schedule and perform basic maintenance, the engine should go another 100,000 miles without complaint.
