Looking for the part
Tamworth
Car: 2014 Nissan Pathfinder R52 ST
Hi,
I am looking for the part for my glove box for Nissan Pathfinder 2014 R52ST. The box is ok but the thing hold the latch in place is broken( I dont know its name)
Pls see attached picture. Appreciated if someone can inform me about it.
Brgds
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Tamworth
Hi, thank you for your reply. Pls see attached files for clear pictures , pic 2is left side, missing part, pic 1 is right side( normal).
Pls help to find its part number.
Brgds
VStar650CL
Technical Expert
If you look at the diagram on the parts page, there are no small parts shown with the glovebox frame besides the bumpers. That generally means the insert you're looking for is part of the assembly and not available separately. There's one good used assembly on eBay that shows to have both inserts, or you can hit the JY:
https://www.ebay.com/itm/274910249983
mdmellott
Car: '13 Kia Soul+ 2.0L AT
May be this piece. (73953-3JA0A) https://parts.hoseltonnissan.com/a/Niss ... _680A.html
For some reason the left-hand piece is 5X the cost of the right-hand piece but they look to be mirror-image identical and similar to the Altima pieces yet the Altima has left and right side pieces priced at the same comparably lower cost. That's just odd. https://www.ebay.com/itm/183469556976
VStar650CL
Technical Expert
The L33 Altie and R52 Pathy actually shared quite a lot of parts, including the shifter and a lot of electronics. Weird that the parts drawing doesn't show a dotted connection if those are the right pieces, but sometimes the interior drawings are truly crappy. Anyway, it wouldn't surprise me if the Altima parts fit right in the hole.
Tamworth
Got the part number from dealer . It is 739533KE0A , nil stock, have to order from Japan and cost $160 .
Anyway can I found it on ebay please
VStar650CL
Technical Expert
The only thing I see on eBay is that whole assembly. Those aren't hard to change, 7 phillips head screws as I recall. Three top, two bottom, two in back. Or hit the U-Pullit. There are many more R52's with charcoal interiors than almond, so the part shouldn't be hard to locate.
