Looking for 1994 q45 differential change
Mrrr407
Car: 1994 Infiniti Q45
What options are there I can do with the drivetrain And suspension because my rear diff is very rare to find and I don’t want to get rid of her :iconeek
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
what's the issue with existing diff?
I'd look into a 'punkin' specialist to rebuild....
Mrrr407
It’s hesitating to takeoff in the morning and it’s making a roaring (humming sound)
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
hesitating to take off?? that sounds unrelated to the differential.
you checked the fluid level? suggest start with a drain and fill with Redline 75w-90 (GL-5+)
it holds about 1.2 Qt.
Ryantzer
Car: 1990 Infiniti Q45
A hesitation to take off sounds far more like a transmission issue than differential problem. When were the fluids last changed in both of them?
macgiver
IF'n it had a VLSD , maybe it's a typical setup with no side gears? or (small) pininion gears? - but ONLY splines inside sealed unit with "flow" torque plates and viscous fluid - ......turned to MUSH inside ? and making this noise , AND slipping due to aged & worn out viscous fluid ?? Just throwin it out there , I'm not any expert on VLSD , even though one's in my J30 , they're nice when still tight and tough !!
'94 Almost 30 years ago , loooong time .
sandydennis11
Car: 1996 Infiniti Q45 176k miles
purchased new in 1995
If you ever want to sell your Q , ill pay for trans port and what you want. My 1996 Q45 cost s for 23 years is 25 Grand
