Little bit of rust...
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
attached is a picture of some rust I discovered on my passenger side under the rear door... It seems odd that I have this rust spot here because i have no other rust and compared to my other Q and other Qs ive worked on my Q seems less "rusty"..
Does this look like something I could prevent from getting worse by taking my dremel, sanding it down and then repainting it, or would this be something id want to get fixed professionally.... id like to do something about it before winter rolls around.
Its not relaly as bad as it looks but i used the macro mode on my camera to ensure the highest quality.
qship96
Car: 1996 Infiniti Q45
my qhad similar spots in both dog legs,cought it before it was as noticable as yours,but none the less,got a bodyshop to repair.my guess is they are rusting from the inside out,so most repairs,including mine are cosmetic at best,as the internal cavity probobly is much worse than what we see from the outside.common on almost every 90-96 q I look at in maryland,along with drivers side rear wheel lip rust bubbling near where rear bumper meets the wheel opening-had that fixed also,bubble already reappearing in less than 3 months-again,rust starting from the inside,rear of panel-no way to permanently repair without replacing quarterpanel or patching in a new piece of metal.
elwesso
2007 BMW M Coupe
so is there any way you suggest I could make it better?
PalmerWMD
Car: 2004 350Z
what about squirting toons of naval jelly into there? (after fixing the obvious rust)
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Looks like it is coming up from underneath.
Once you clean it up, I fear there may not be enough metal to repair without some welding.
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
Wes just had this fixed on my car $75.00 per side w/paintingthey cleaned it all out treated it with a product called "rustmore" filled it in and repainted
redmanfx
Car: 92 Q45a
O.M.G Wes! You have to sell it before it gets any worse! I don't know if you can save it now. What have you been waiting for? How much do you want for it? I want to buy it before you let the whole bottom rust out!!
Young kids just don't know how to take care of a fine automobile.
I CONVERTED!
gloucester Q
Car: 90 Q
i've got the same on a 93, but only on the driver's side rear door sill. hoping to get to a body shop before winter too.
BobE
Car: 95 Q45 98K
Move dwn here to flatland. Cars don't rust here. Only time I ever see it is when some Yankee moves here & brings his car...
elwesso
2007 BMW M Coupe
Alright well i guess the consensus is to take it to a shop and see what they can do .....
Rex
Car: None
elwesso wrote:Alright well i guess the consensus is to take it to a shop and see what they can do .....
See if we can get a group discount .
burijon
Car: Went to the darkside...acurazine
I had Maaco give me an estimate of $550 because both rear door entries of mine have rust similar to yours. Needless to say, I had sticker shock from that. You might be better off buying some por15 and doing it yourself with a dremel. Amsoil makes a gear lube(MP Heavy Duty Metal Protector) which has excellent anti-rust characteristics. I have sprayed the underside of all my cars with it and it really keeps it looking new and virtually rust proof. It produces a waxy film that also lubricates.
http://www.por15.com/product.asp?productid=301
https://www.amsoil.com/storefront/amh.aspx
I will eventually get the por15 kit as thats all you really need for a small section. The Amsoil product will really amaze you.
nchopp
One word - BONDO. :-)
JedCoop
Car: 94 Q45t w/TCS, 92 Q45 w/TCS, 91 Q45 touring (RIP)
elwesso wrote:attached is a picture of some rust I discovered on my passenger side under the rear door... It seems odd ....
This is not unusual, and the rust is from the inside out.
On my first Q from Massachusetts Infiniti repaired rust in this exact same spot for me under warranty. I had professionals fix it on my second Q from Kansas.
I'd get a pro to repair the rust... all my attempts previous rust repair attempts on other cars seemed to cause rust to grow more quickly. If you don't do it right, do it simple. Just use a pencil eraser to remove surface rust without loosening things up too much and cover it with touch up paint. I got this technique from a profesional, too. Anything in between seems to make rust grow more quickly. Also be sure to spray some POR15 or other rust "preventative" in the door sills too.
In both Q's with the rust repair work, the rust never came back.
