the additional inertia you can store up in a flywheel isn't enough to really move the car. and any power you put out after the launch goes into accelerating the car and the flywheel. heavier flywheels are better for drag racing (to an extent) because it makes launching easier. it smooths things out, helping you maintain traction.EZcheese15 wrote:The reason you lost time on a 1/4 mile is because the lighter flywheel has a lower moment of inertia. When the car is revved at the start, you increase the inertia. A lighter flywheel has less of an increase, while a heavier one would have more of an increase.
When the car is launched, with a HIGH moment of inertia, the inertia of the flywheel actually helps to accelerate the vehicle faster because the engine has to do less work to get the car moving. With a lighter flywheel, and LOWER moment of inertia, the engine has to work harder to accelerate the car. For this reason, a Pro Drag racer will opt for a HEAVIER than stock flywheel.
the benefit of a lightweight flywheel is also it's disadvantage. if it accelerates (spins up) faster, it will also decelerate faster. the same holds true for everything, driveshafts, brake rotors, anything with mass (though this discussion is about rotational inertia).240marcuSX wrote:ive always figured that a lightened driveshaft would be just as beneficial but less detrimental
No, it's not enough inertia to *move* the car. However, the inertia that is stored when the flywheel is spinning in neutral transfers throughout the drivetrain when the clutch is engaged. The inertia from the flywheel does *aid* in transfering the inertia to the wheels. Because of this, the engine is required to do LESS work to get the car moving. I never said the inertia in the flywheel would *launch* the car, I said it would reduce the work load on the engine during launch, which in turn allows the engine to utilize it's power to increase the inertia of the vehicle even more.cdlong wrote:you guys need to study physics a little more.
What about when going up hill?EZcheese15 wrote:The only "torque" you loose is launch torque. That's something you don't need on a roadcourse. Ever see a pit crew pushing a car out of the pits to get it started? That's because the flywheel is so light they can't even get the car to start moving.
I honestly can't think of a reason that a heavier flywheel would *not* benefit your 1/4 mile time.
You would negate the benefit of the lighter wheel by doing that.2BN_S13 wrote:Couldnt you fein rotational mass by simply using a dense material as a ring with spokes design flywheel instead of just a solid design?
