I searched on other forums and came up with this food for thought:JDRosenberg07 wrote:
Benefits Include: Reduced mass equals increased acceleration. Improved mid-range torque in a normally aspirated engine due to not having to overcome the heavy weight of a stock flywheel. Faster Revving and decreased deceleration. The benefits are mainly in the lower power band and lower gears.
The main drawback is cost of installation. It can be a bit $$$
Modified by JDRosenberg07 at 9:58 PM 7/25/2009
I agree with your assessment of the companies involved. They do make quality products, and you are correct, they would not stay in business if they made inferior products. Forgive me if I left you with the impression that the companies are the 'fly by night', here today, gone tomorrow type that you sometimes see selling items on e-Bay. And no, I'm not saying that all companies that sell on e-Bay are shady.JDRosenberg07 wrote:Well I just emailed the companies over the weekend so I'm still waiting to hear back.. Installation i'm not sure on but could be around $600 from what I've heard.
As far as gains go there are more gains in the lower and mid range of the rpm band and decrease the higher you go. I don't have exact numbers and I will try to get a reasonable estimate from the responses I get but from what I've read it can be pretty significant.
Lenny, I appreciate the extra insight as I am not an expert when it comes to mechanics but i have done my homework too, all the companies I've emailed are all well known companies that are well experienced in making flywheels not some joe schmo I found on eBay so I don't think anyone should worry about them not being properly balanced or poorly made.
Second, I'm not asking them to make a 7lb racing flywheel, my A/C is my DD and I'm not looking for anything extreme. JWT made one for the earlier model altimas that was 12lbs, half the weight of the OEM flywheel according to their website. So low end chatter or stalling due to loss of inertia is unlikely.
If a company is willing to make one, trust me to make sure they will do it right I have never been one to go half a$$ on anything, especially something that could potentially blow up my engine if not done properly
1. Why would you recommend a performance clutch kit as well? what benefits does it provide and how does it work with / enhance the flywheel mod? (just stronger and more durable to handle the added power from the flywheel?? if u cant tell im a complete newb lol)Throckmorton wrote:
I'm not sure that spending between $1200.00 and $1800.00 for a performance clutch kit and performance flywheel is cost effective, as there are a few downside 'cons' that factor in the equation for street driven vehicles. Race track driven is a different story.
A performance clutch would only be necessary if you were to drastically increase the torque in your car, like adding a turbo or super. If you didnt upgrade your clutch and increased your power waaaay more than stock, your stock clutch could and most likely slip and not hold the power.RobPaulson wrote:1. Why would you recommend a performance clutch kit as well? what benefits does it provide and how does it work with / enhance the flywheel mod? (just stronger and more durable to handle the added power from the flywheel?? if u cant tell im a complete newb lol)
These arent neccessarily racing parts, im not looking for a 7lb flywheel like i stated in an earlier post, im looking for something around 12ish lbs which is not extremely light.RobPaulson wrote:2. If you do install all of these 'racing' parts, how does street driving cause potential issues?
rich2342 wrote:How exactly is that? If the flywheel is properly machined and balanced it would no more throw off the synchronization of the engine that the stillen pulley does, which is none btw, and both are connected directly to the crank.Throckmorton wrote:Good Post man.. It's not all roses when you go from a Dual mass flywheel to lightened rotating mass slywheel. It can throw off the synchronization of the engine and affect gear shift and transmission life.
And the same goes for gear shifting and transmission life. some flywheels actually prolong the life of your engine and transmission as they dont have to work nearly as hard to move the vehicle.
It is not an assumption as stalling due to lack of inertia happens when the flywheel is extremely lighter than stock. I have already stated that i am not looking for an extremely light flywheel. i am simply looking for something that will decrease the rotational mass of the stock flywheel. And yes while some inertia will be lost it will not be so much that it would cause you to stall out.Throckmorton wrote:I do have a question. You made the statement: "So low end chatter or stalling due to loss of inertia is unlikely.."
How do you know that? What facts do you have to show that this would be the case with a late model 2.5 Altima?
In my opinion, that is a rather large assumption, as you state: "Well I just emailed the companies over the weekend, so I'm still waiting to hear back.. "
There may be however some added vibrations due to switching from a dual mass flywheel, used to reduce engine vibrations, to a light weight or single mass flywheel.From the Fidanza FAQ website wrote:6. CAN MY FLYWHEEL CAUSE CLUTCH CHATTER? – Yes but it is only possible if the clutch has extreme heat damage due to excessive slipping of the clutch. The type of clutch disc material used causes most clutch chatter. The more abrasive and “grabby” the material the more chatter you will have.
The price i found for installation was simply an estimate i found on other websites were for other vehicles and was only to be used as a rough estimate. The actuall cost of installation will vary. as will the price of the flywheel and clutch.Throckmorton wrote:You mention a price of $600.00 to install the flywheel. That sounds reasonable. Checking the Stillen website, and yes, I am aware that they as yet do not make one for the late model 2.5, I found that similiar performance flywheels cost around $600.00, and clutch disc kits are also in the $600.00 price range. In my opinion, it would be prudent to install a high performance clutch kit when the flywheel is installed.
lol 7? http://forums.altimas.org/zerothread?id=366113JDRosenberg07 wrote:Yeah i know there arent as many MT's on here but impretty sure we have more than 7 on this forum between the sedans and coupes. I mean look at the short throw shifter, if there wasnt enough MT's racingline wouldnt have come out with it.
JDR,JDRosenberg07 wrote:
I believe Lenny suggested installing a clutch and a flywheel at the same time because it would cost way less on labor then if you have one installed and then a couple months down the road install the other.
So if your only adding bolt-on mods that have some gains but is still in spitting distance of stock power then you should be fine without a performance clutch. It doesnt exactly enhance the flywheel, as the flywheel does not technically "add" power, it just reduces rotational mass to accelerate quicker.
do you have any mods or plans to mod you car?Throckmorton wrote:I hope for your sake your comment is correct. I just am not prepared to take that risk for my car.
and i gotta agree with youmcheddadi wrote:this thread is so formal it makes my head hurt
You may be right. A few things could have caused the low number of responses. By you posting this in the correct section and not the coupe section. that could have hurt it.JDRosenberg07 wrote:So I guess no one is really interested in a flywheel then
My thoughts exactly... Lol so I guess that makes it LBC's fault then...dldjros69 wrote:
Bahh i still want one.
The only problem with that is the company needs a stock flywheel and a minimum of 10 orders in order for them to make one.peteyd wrote:im still interested depending on a price for the 3.5
I think the biggest risk is in finding a mechanic you trust to open up your engine and put it back together correctly. Barring a block rebuild or major warranty work, the only way anyone is going into my engine is through the oil fill plug, and the only thing going through there is going to be oil!Throckmorton wrote:I hope for your sake your comment is correct. I just am not prepared to take that risk for my car.
as far as i know you dont have to open up your engine to get to your fly wheel its all transmission work which is why its recommened to have the clutch and flywheel all done at the same time to save money. any reputiable transmission shop can do it but itll be costly because you'll have to drop the engine more then likely to remove the transmission.1125Altima3.5 wrote:
