Lights on dash come on for no reason.....
A home for 1983–1989 300ZX owners!
kefferjoe
Car: 1986 Nissan 300zx & 1999 Nissan Pathfinder 4x4
So the warning lights on my digital dash are coming on as well as the battery light when the car is run at higher rpm's...i have a new battery and fairly new alternator (i hope its not the alternator again) but the gauge seems to be sitting at the right level and it fluctuates with the rpm's...could it possibly be that the belts are over/under tightened?? Or is there a completely other reason??
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I'd make sure the belst are tight enough and then I'd trak doen clean anc retorque all grounds you can find
kefferjoe
So after getting ticked off with three different autozones I went to checkers (who might I add work a lot better and more efficient) but they were able to tell me it was the diode and I needed a new alternator which suprisingly are cheaper than most alternators on other cars
HowlerMonkey
Car: 1991 Infiniti M30 wi/ L28ET
If you are going through alternators, you could have a bad connection between the negative battery terminal and the body.
I would make sure that connection is good first because a lifted body ground there can eat diodes.
Return to “300ZX (Z31) Forum”
