Smarty pants! That's what I left him as a comment on his cardomain!Sentientbydesign wrote:You might want to update you cardomain profile. The 35 in I35 indicates you have a 3.5 L V6 not a 3.0 like you have listed.
That's still a good chunk of money for them to not even fix anything. There's not even any labor involved - a money could run a diagnostic test on the car.Sentientbydesign wrote:Not sure if this will work, but you might try taking it to a Nissan dealer instead of an Infiniti one. When I had my I30, they were only going to charge me $90-$95 for the diagnostic.
lightsout wrote:AUTOZONE has another bigger(yellow) code reader besides the OBDII. I would recomend purchasing that one for i think a couple hundred bucks...then you can scan your computer all day if you wanted to.
Same thing happend to me with a different issue. The phrase "we couldn't recreate the problem" still pisses me off even a year after my dealer/warranty experience. Unfortunately it had to end with my lawyer friend calling the dealer and informing them that they were going to keep the car and drive it around the block every 5 minutes until they found a problem.sfarace wrote:I've been to the dealer 3 times. First time they said my back tires were the wrong size. Replaced back tires, still happened. Second time I left the car at dealership for a mechanic to road test. He could not reproduce the problem. SLIP light never came on. NO computer code error. Third time I went on road test with mechanic. Still could not reproduce the problem with the Slip light, but he did feel the car drifting back and forth when going over 65 mph. He said the car was not driving right and that he needed to download the computer results. They called me the next day stating no errors detected and the car was fine since they could not reproduce the problem. I asked them to look into the problem further since I really don't feel safe driving the car. I was told to pick up the car and that I would have to file a claim with Infiniti corp office.
