jt15833 wrote:pics of air-water IC setup? I am interested in this setup but debating as well. it's either that or a v-mount for me, i desire the short IC pipes.
anyone know if these are able to cool better than air-air setups? I have researched a little and for what i concluded, they do better for sprints but once the water heats up it is not as efficient cooling.
nice build though wish i could add more.
Water cooled are generally less efficent and require a secondary pump and often a secondary source to flow the water(coolant or w/e) through the IC itself. The washer sprayer is usually the tank utilzed, but you are going to need a secondary pump. We debated using the stock MS6 pump and running a water cooled setup on the MS6 IC setup, but it isnt efficent enough to flow and try and redirect the radiator fluid. It also leads to a hotter fluid transfer.
they are pretty ideal for drag cars as you can then use ICE in the water source to make the water as cold as possible.... but street driving this isnt effective at all and the charge is not cooled as much as a similar setup with a FMIC would yeild.
N62s are a great choice but arent they only good for 300 or so WHP? or am I think of the N60s?
I have to P60 mafs sitting in storage. they are fing huge.
def want to go standalone with water/meth. going to be about the same price or even cheaper than just about any rom tune.
if 444s are free...... I would take them and run...... u can upgrade later, but might as well take them and run. The evo injectors tend to be all over the board on flow from what others have experienced....... I would shy away from those.
the stock mani is good for alot of HP, other than it is a bit of a pain to remove.
PS with proper tuning.... anything is possible. If you are really worried about lag, there is always cheater juice......
