I went to the Nissan section as shown in the code#.Retired Chief wrote:When you went to that site for your spoiler, did you go to the Toyota section and buy it from there or did you go to the Nissan section and get the one that looks like the Celica wing? The reason I ask is the one in the Toyota section may look more like the original Celica wing but the mounts/alignment may not be right for the Z.
The roadster trunk has a 'horizontal line dip' going across the trunk & I wanted the wing pedestals to set exactly at the edge of the line...in order to get this done I had the body shop guy do the job because there is very, very little room for error in shaving the bottom base of each pedestal. The wing also needed to be sanded & prepped.The rest of the body work I did myself along with the help of my buddy.
