LED conversion oops
ShawnTexan
Car: 300ZX, Nissan Titan
Ok so i decided to switch out all the front lights to LED, also i read up on twin turbo .net on jumpering the wires over and this allows u to run all the light on if u want so i did that also but i pretty sure i did it wrong. so now my turnsignals dont work they dont blink im going to replace the flasher module next see what that does. but weirdest thing is when i turn right trun signal on dash blinks and turn lights blink. im including a piucture of the harnes and the pins i jumpered are the black right end 1 and the 2 pins over green and yellow 1. its a 1994 if that matters. thanks
rgregoryb
Car: 1992 300ZX 2+2 NA
Sometimes LED lights will not work as a turn signal unless you add the "adapter" they can not respond fast enough to the. Changing current . This is very common on older cars.
rgregoryb
I get my led stuff from "superbrightleds.com" they also carry the adapter you will need. It's called a load resistor runs about 5 dollars.
budget300zx
Car: 90 300zx NA
just change out the flasher with one of these and not worry about adapters.
http://www.diodedynamics.com/store/led- ... al-flasher
location of it
ShawnTexan
I got this problem figured out switched flasher still didn't fix problem of dash lights blinking figured out that it only did it with right turn signal on and the problem was the right front led turn shorted or something causing all the problems.
