Whoever designed the LS8's enginebay arrangement should be hanged. It makes the Q45/VH45 enginebay look roomy.
I had intended to replace my spark plugs today. I had to go buy a tiny 7mm box wrench to get two of the six coil cover bolts off. Then when I got the bolts off...I couldn't get the COVER off. The coil cover is glued in place with RTV from the last times I and Ford dealers have opened it. I'll crack the composite before I break the RTV lose.
It sucks having no car people in the area. An extra pair of hands would probably do the trick.
Still, the 2nd gen is a lot better laid out than the 1st gen. 1st gens had ridiculous intake plumbing running all over the damn place:
