mkaresh »
https://forums.nicoclub.com/mkaresh-u51469.html
Thu Feb 21, 2008 2:58 pm
It means that for every 100 Versas, there will be 68 repair trips that include a successful repair over the course of a year.
Batteries are excluded, so that trip wasn't included in the analysis. I know that sometimes the battery should count, but it would require overly detailed (and lengthy) instructions to deal with that sort of gray area.
The golf bag bit I wasn't aware of. That's a tough call, coming down to whether the broken part should have been able to stand up to the conditions it was subjected to. People regularly put heavy luggage in trucks, so the bits back there should be sturdy.
The program has an outlier control built in, such that the car with the most repair trips is adjusted to the next-highest number of trips, plus one. Which about 90 percent of the time means no adjustment at all.
The actual distribution for the 2007 Versa, with 131 cars reporting for about half a year each:
99 cars (76%) with no repairs23 cars with one repair trip6 cars with two repair trips3 cars with three repair trips0 cars with 4+ repair trips
This is a typical distribution for a car with an average repair rate.
The fuel economy example is an extreme, unrealistic case. Someone making the same argument performed the actual computations with their numbers, and the difference was a few tenths of a mile per gallon. And the more tanks / people you include, the smaller the difference between the two methods will be.
That said, I'll likely offer results using the more precise method in the future.
