Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Jan 27, 2004 1:36 pm
When ever you buy something used, always disassemble and clean and rehab it yourself..........sitting for years without moving is a problem.........engine, transmission, diff, starter, CAS, IAC, brake calipers, fans.............easy to rehab a working starter.......some fine sand paper and a fine tiny file.
The starter shouldn't take you more than 4-5 hours with a lift and all the tools.............easy compared to the plenum located starter on the LS400.
Careful about letting someone else do it we see them swapped all the time with the top bolt missing.
