..last one for tonight
RagingPanda
Car: 78' 280Z
it's me again sigh. Am I the only one who have problem taking the head bolts off? I have a break bar and everything n that thing didn't move!! I'm following the FSM's order of taking them out but does it matter if you're looking from the intake side or the turbo manifold side? I don't think so but just to make sure.
float_6969
Do you have allen sockets, or just an allen wrench?
RagingPanda
Car: 78' 280Z
float_6969 wrote:Do you have allen sockets, or just an allen wrench?
socket, extension, and a breaker bar. i'm going to give it one more try
iliketocrash
get a 10' piece of PVC pipe for a breaker bar. we had to do that on my friend's car once cause the previous owner torqued down the headbolts to 115ft/lbs and factory specs i think was supposed to be like 70ft/lbs or something. anyway, it was real easy with 10' of PVC cause i just walked around the front end of the car with the pipe and it involved no effort, just walking =P
nab911
Car: 93 Nissan 240SX SE
I used a 5'er once to take off cross threaded lug nuts.. Just get the longest thing you can find.
RagingPanda
Car: 78' 280Z
iliketocrash wrote:get a 10' piece of PVC pipe for a breaker bar. we had to do that on my friend's car once cause the previous owner torqued down the headbolts to 115ft/lbs and factory specs i think was supposed to be like 70ft/lbs or something. anyway, it was real easy with 10' of PVC cause i just walked around the front end of the car with the pipe and it involved no effort, just walking =P
nice. What does the FMS mean by loosen the bolts in two to three steps?
NeedCAforS13
Car: CA swapped S13 coupe
so you don't warp the head with one bolt real tight when the others are loose... you have to do little turns on each bolt in the proper order to get them loose. try breaking them all loose, then doing 1/4 turns or so.
Sean
RagingPanda
Car: 78' 280Z
you guys are awesome! thanks for everything and I'll post some pics up later.
