L320 engine choices
1962-1965 Datsun L320 and NL320 forums - The truck that started it all in the US. All 320-specific topics and discussion can be found here.
a320inMaine
Car: 1965 Datsun L320 PickUp Truck
Hi,
I recently bought a 1965 L320. My truck doesn't have a motor or transmission. I REALLY need to get some ideas about what engines/transmissions (Datsun or otherwise) would work. Being in Maine with this 320 probably puts me at a disadvantage, but I'm in hopes someone can steer me in the right direction.
65tuxedo
Car: 05 G35 Coupe
I am interested in this topic also. Wondering if there is a simple later model engine upgrade.
Help us out guys!!
Not too many options, unless you want to do some cutting.
The most common swap I see is the A14 / A15 out of the B210. Plentiful, cheap, and they'll run forever.
Personally, I'd just look for the original E1 engine and rebuild it. I'll ask around, they're out there still.
1962 datsun
Car: 1962 1965 L320 datsun ... 1964 NL320
I have 2 extra motors 1189cc which is a 1200 cc motor both with tranmissions if intrested let me know Aloha Willie...
a320inMaine
Whatcha got in mind and how far away from Maine?
a320inMaine
Hey AZhitman,
I found an engine & 5spd transmission that the owner said came out of an '82 210 sedan. Gonna take a look but don't know how to id it; you know, A13,14,or 15? I'm hoping its all he says it is. Thanks in advance for any help on this.....Thx
a320inMaine
Scored an '80 A14 motor and 5 spd with less than 21,000 real miles!........ now on to the rebuild!
Nicely done!
Trans tunnel will likely need to be cut / expanded. IIRC, the trans on the A-series engines is larger.
a320inMaine
Is the 320 trans tunnel any different on the floor shift model(which i own)? If need be, the plasma gun is gonna get some use. I am going to 'dry fit' the unit in before I separate the transmission away; that way I can get an idea of how much of a change the tunnel will need. Gonna move slow on the rebuild - snow season here shortly so no great hurry.
Return to “Datsun 320”
