KONI Sports for Classic Z's
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
[email protected]
Vendor
Car: 1971 240Z
Postby [email protected] » Tue Feb 05, 2019 4:09 pm
Motorsport has joined forces with KONI to create an exciting new product, one of the most requested upgrades for early Z-Cars we've ever had, to replace (and improve upon) the departed Tokico HP & Illumina Adjustable Struts. Completely new, constructed specifically for 70-83 Datsun 240Z, 260Z, 280Z, & 280ZX, these externally-rebound-adjustable, twin-tube low-pressure gas-charged KONI Sport (Yellow) Struts are designed for use on both stock & modified street cars, as well as autocross & track day cars. Built to give a good balance of street ride quality and handling at the softer end of the adjustment range, the KONI Sports can easily be tuned up to nearly double the rebound damping force for more aggressive control needs: simply open the hood or rear hatch and turn the KONI adjuster knob. Not only can you tailor the struts to your local road conditions (and to your taste), you can also quickly and easily change the settings for a blast at a weekend autocross or mountain run, then easily re-set them for a relaxed ride home. Whatever suspension behavior you need is literally at your fingertips. Also, if you race on different tracks and race conditions, the adjustable damping gives you an edge in setting up your car specifically for any track or autocross course. Koni believes they will work great with Eibach Springs, and will be fine with even lower springs, as long as a proper bump stop is used. Let us know if you have any questions, [email protected] & I will get you an answer.
The first shipment, for 70-8/74 240Z & Early 260Z, is expected to arrive in the U.S. this March. We expect to receive the 9/74-78 Late 260Z & 280Z Struts 3-4 weeks later, and then the 79-83 280ZX Struts/Spring Seats 3-4 weeks after that. To reserve your set from the first shipment, the Pre-Sale is on now at https://www.thezstore.com/page/TZS/CTGY/classic20b04, where we also have more information (and more to come soon), more about KONI, an adjustment video, and a test drive report from Hector Cademartori.
[email protected]
Vendor
Car: 1971 240Z
Re: KONI Sports for Classic Z's
Postby [email protected] » Wed Jul 31, 2019 1:37 pm
Just in case anybody missed the other threads, 70-78's are in stock. 280ZX's are expected in September. Contact us with any questions at (714)639-2620, (800)633-6331, or [email protected].
[email protected]
Vendor
Car: 1971 240Z
Postby [email protected] » Wed Nov 06, 2019 8:40 pm
Oops... Guess what arrived in September just like we said? Our apologies for saying we'd announce it when they arrive, and then neglecting to...
Here they are! The front 280ZX cartridges look and function basically the same as the 70-78. However the rear shock/spring seat version features a little extra. Note that these are designed with a 3 position spring seat perch. So if you know you will be touring often with lots of luggage and want a bit more ride height, you can set them to the top position. If you want them to ride a little lower, set them to the bottom position (they are set during installation, to change the position later, the struts must be removed). Nice little option to have available, thanks Koni!
So now the Koni Adjustable Sport Yellow Struts/Shocks have been completed for all of 70-83 240Z, 260Z, 280Z, and now 280ZX. We've heard some good reports so far where people like how they function, especially with Eibach Springs.
Thanks again to Koni and Lee Grimes for all the great work!
Return to “Advertisers' Marketplace!”
