KNOCK SENSOR
jdmDAvey
Car: 89 Fastback..CA18DET, Front Mount, Kei Office Coils, Mandrel Bent 3"!
i have an 89' 240 that i just put a CA in. I hooked up the knock sensor but it doesnt run right and is throwing a code "34", which is the code for knock sensor. I am just wondering how do you wire it up correctly, so that i can double check. There has been so many different posts on how to do it, i might have done it wrong. I have also tried to use a 10k Ohm resistor connected to the ground wire, and still have had no such luck. Any help is appreciated.
And YES, I have searched a lot.
Modified by jdmDAvey at 5:45 PM 7/29/2005
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
just wire it directly to the ecu. dont bother trying to splice it in anywhere, just run wire from the pins on the ecu to the connector on the knock sensor. thats what most people end up doing.
- tim
jdmDAvey
Thanks for the help, I'll give it a shot. Its the only thing i havent tried yet.
NeedCAforS13
Car: CA swapped S13 coupe
mine is hard wired to the ECU as well.
8ggalant
Car: nissan cefiro
well it this just started happening to me today but im throwin the code as well...but i checked the connection (hardwire) and its fine...also checked @ the block and its fine...do i need to replace it...if so w/ what...checked the parts page and all the knock posts...any suggestions??
float_6969
Does the plusar have a knock sensor? I would think it would. It should be the same.
8ggalant
Car: nissan cefiro
float_6969 wrote:Does the plusar have a knock sensor? I would think it would. It should be the same.
thats what i was thinkin...im gonna look it up now
NeedCAforS13
pulsar one should work. I've never replaced mine, but I know they are $$$ new from the dealership
8ggalant
Car: nissan cefiro
NeedCAforS13 wrote:pulsar one should work. I've never replaced mine, but I know they are $$$ new from the dealership
ouch gotta pay to play tho i guess lol
jdmDAvey
OK, so I've got 2 options... Hard wire from 23 to sensor, which I already tried and it didnt work. Or... Run the resistor from 23 to 20 without looping it? Which didnt work also. So what I'm trying to clarify on is should I hard wire the resistor from 23 to 20 inside of the ecu? And, having it wired into the harness, is it picking up other signals? Hum... The weird thing is that she still acts like the knock sensor is messing with the timing and throwing off my a/f, even though its not currently wired. BTW, it majically started throwing code 12 also, which is the AFM. Any ideas. Thanks again
8ggalant
Car: nissan cefiro
from my understanding if the knocksensor is not connected it will still act as if it seeing detonation...(happened to me)...
try checkin the voltage/resistance (whatever it is) to see if the knock sensor is any good (instructions in the fsm)...im doin this tomorrow tho im pretty sure i need to replace mine
jdmDAvey
Thanks man. Good thoughts. Hey if you need a junkyard knock sensor for some reason, I think Im going to get a couple tomorrow.
sdtouge
Car: 1990 240sx coupe
any one ever try to just unplug the sensor out of the block, and just ground the actual sensdor inside your car and plug it in somewhere like that lol?
onevia1800cc
Car: 1989 240sx ps13
this might be off topic butwhat EXACTLY are your symptoms from this??i am wondering as my ca backfires and runs rich as i accelerate, sometimes it will run perfect for 20 min or more, then she wants to start backfiring and sputtering i have changed my coilpacks, changed my ignitors (i have 3) i'm about to try swapping my coolant sensor this is driving me crazy. just thinking it might be the knock sensor is incorrectly wired
8ggalant
Car: nissan cefiro
ecu will pull timing...u'll get alot of misfiring/backfiring under boost...umm...those are the ones ive seen...there may be more tho
davey...let me know if u find an extra sensor
onevia1800cc
i have seen one sold under nissan pulsar on ebay or ca18/ca18deit was like 25 BIN
