Knock sensor connection location question
ZiprHead
Car: 1999 Infiniti Q45 base
About to change the knock sensors and I want to make sure the parts I got are correct. I found two connectors just in front of the intake plenum on the right side of the engine. The connectors are very similar but not the same. Wondering if I got the wrong parts or if I'm not finding the right connectors. Any help will be very much appreciated.
The car is a 99.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
pictures?
this is the correct factory part number for a '97. It's possible the '99 might be different?
HARNESS, ENG SUB INF#24079-6P020
MowgliCSM
Car: 99 Q45t, 07 S550, 89 Mitsu Mirage Turbo.
Knock sensors would be bolted down under the intake plenum. Replacing the harness was a good idea on the G50's, but the Y33's never really had an issue with them degrading. Also make sure you have genuine Nissan KS's. Cheap eBay China ones will more than likely cause you issues down the road and it's not worth the small amount you save.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
MowgliCSM wrote:
Thu Oct 24, 2019 2:04 pm
+1.
Note that Genuine Nissan KS (22060-30P00) will have JECS UNISIA stamped on them. Beware that there are KS out there that appear to have a Nissan parts tag on them, but are counterfeit (hint: scan the bar code and see the p/n does not match).
Ludeaem
Car: 2000 Infiniti Q45 AE
I am pretty sure OEM is Hitachi. I bought them on rock auto for $40 a piece
