BlackNWhite wrote:Not to rain on your parade or anything... but is it easy to take off if you're in a pinch?
Because how will you get into your car if the battery dies?
Looks really good though!
yea it's pretty easy... if you have door closed, you just pull the handle like you were to open it (make sure u have a small flathead tho), and pry off the piece.... thus revealing the keyhole... here's some pics i took when i did it
u can faintly see a red circle, u want to use a flathead screwdriver or what ever you have that is able to get into the space to lift the tab up. As you lift the tab, pull on the cover to remove it. and presto!
