kaT ignition prob?
isetkidsonfire
Car: 93' 240sx SE coupe
I've got a kat with fmu, 7psi, rebuilt w/stock internals and super t70 turbo.
The problem im having is that it seems like the ignition cuts randomly here
lately. one occation the car acted like it had a rev limit of 2500 (knock sensor?)
it's normally more like a stutter. the turbo oil seals are leaking only under
vacuum it seems but im not sure (turbo is old). pulled codes from ecu and got
12, 105 ; mass air and egr which makes sense with no tune and no egr
connected. Resently changed out a cracked gas tank with a new one btw. Any suggestions?
574-240sx
Car: Nissans, Toyotas, Subaru
Bad maf will cut out at 3K but I have had it happen a few hundred rpms sooner and later then that. Get a basic tune before you hurt something then trouble shoot from there.
