poneyrunner »
https://forums.nicoclub.com/poneyrunner-u160662.html
Sat Mar 26, 2011 8:26 am
like it says is it a straight swap? I have tried to find the info on this and all i can find is that if you use the kae pistons it increases the compression on the de motor. I also found that the earlier motors came with forged rods and the e motors not only had forged rods but also forged pistons. can anyone verify this? What i am wondering is i have a kade motor in my car now that i spun a rod bearing in. and i have access to a good kae motor with a blown head gasket. What i want to know can i put the crank rods and pistons from the e motor in my de (obviously with new seals and bearings and honing it) will it straight bolt in? and what kind of compression will it be running then? i eventually plan to go big for boost to hit the 400 mark but have not finished peicing together my stuff and want my car back on the road and at the track. please help me out.. or maybe you can guide me to where i can find out this info.. thanks
