240ShaneX »
https://forums.nicoclub.com/240shanex-u127219.html
Fri Jan 28, 2011 6:17 pm
JKL, do you notice any oil in your coolant when you drain it, or constant bubbles when burping? If not then you prob have the same problem I did. BLEED the crap out of it. rev it at all different rpms for like a minute or two each time (make sure your thermostat is good by dropping it in boiling water and see if it opens up).
When bleeding, open the bleeder bolt (10mm on the top of the intake mani by the top hose) and fill your rad with the car off until it pours out the bolt hole. then squeeze your hoses to get all the air out of them while continuing to top the rad off to keep it full (a funnel with some electrical tape at the bottom shoved in the rad hole helps ensure that air doesnt get back in as its bleeding). keep the funnel about 1/4 or so full. then start the car and when you see coolant gushing out the bleeder bolt hole put the bolt back in. then with the funnel in the rad, rev it a bunch of times til you see no more air. I did this for almost an hour to make sure ALL the air was gone.
one way to see if theres still a lot of air is to squeeze the rad hoses while the car is running and hot. you should be able to feel the pressure and resistance (with the cap on and bolt IN). if the hoses feel like there is still a lot of air in them, and they are easily compressible, then shut the car off, open the rad cap, and open the bleeder bolt. then add more coolant/water and keep squeezing the hoses to get all the air out.
BE CAREFUL NOT TO BURN YOURSELF!! you can open the cap and while hot if you have a glove/towel to protect yourself. once the cap is off, the pressure on the bolt will be gone too, so you can remove that and bleed it again with the engine off, then on til it starts to flow out the hole consistently. my recommendation is that you always put the bolt back in before you close the rad cap, and take the cap off before you open the bolt so the bolt doesnt possibly shoot out.
I know this is long but, and I repeated myself a bunch of times, but hopefully it makes a little sense!
Also, like the other guys said, jack the front of the car up from the cross member if you can.
Goodluck!!
