xyzalvarez »
https://forums.nicoclub.com/xyzalvarez-u73749.html
Tue Oct 30, 2007 8:44 am
Ok, i been searching and well i rather ask...
im planning to swap a KADE into a datsun 510...( before you say something, the 510 forum tells you about motor mounts, and motor installation using 510 wiring)
im looking for KADE basic wiring info, i want to run the basic wiring in order to use my stock ECU,,, and ditch emission sensors and unnecesary plugs...
My engine its a 95 MT with 95 ECU, but im having problems finding the 95 harness ..( overpriced )
instead i would like to run ( in case i cant run the 95 ecu) the 94 and early ECU and harness...but im wondering whats the most necesary sensors to use...and avoid codes or limp modes and remove unnecesary stuff .
i understand the MAF , dizzy , injectors...but what else?should i run a SAFC ? or what other route i can go....
somebody has a basic wiring info.?!! thanks
