smug510 »
https://forums.nicoclub.com/smug510-u8061.html
Thu Sep 11, 2003 6:42 pm
well i just finished mt turbo setup on my sohc , the oil feed line is a 3' long -4an line that connects where your oil pressure sending unit goes , you just replace the unit with a "T" fitting so you can retain your sender , than the other side of the t you connect the line , and on the other end of the line you hook up to your turbo, than the drain line has to be pretty big like -10an so the oil can drain without building pressure in the turbo [makes the seals go out faster] than you drill a hole in the oil pan for the drain to go , now you have two options , you can have a fitting welded to the oil pan , or ive seen a kit with a flange that bolts to the inside of the oil pan to a outside flange that basicly clamps the oil pan , with a fitting on it [ no welding ] but both fine , just the basic idea is to make the drain go straight down to the oil pan without going above the turbo [ gravity drain] and thats about it good luck
