VISALIAGRAPH »
https://forums.nicoclub.com/visaliagraph-u215244.html
Mon Jan 28, 2013 9:34 pm
Hi and thank in advance for any help here,
Changed my timing chain this weekend. Got a kit with sprockets, chain and guides. As well as a new tensioner. Upon researching I saw it stated more than once that after finding the compression stroke of #1 TDC its a simple fact of lining up the discolored chain links with the punches on the sprockets. This I did. Then put in the oil pump so the distributor was aligned to first firing position. Second try nailed it. Pretty pleased at this point. All put back together, started it. Ran almost wimpy sounding. Tried a bit of gas and it stalled and wouldn't start again. Am I missing something here. I'm afraid I have a piston to cylinder strike but after such attention to detail could there be something I missed? Wouldn't the links to the punch marks prevent something like this? More info is available if needed. Thanks!
Jeff (VisaliaGraphics)
VISALIAGRAPH on Mon Jan 28, 2013 11:56 pm, edited 1 time in total.
