Ignoble »
https://forums.nicoclub.com/ignoble-u119254.html
Sun Nov 02, 2008 9:35 pm
I had a sound like this in my car, at first I thought it was noisy valves or lifter. Not sure if its the same for you but turns out my exhaust manifold bolts were broken off, which created an exhaust leak (tick tick sound). After a while the engine heated up well enough for the metal to expand and stop the exhaust leak and noise. Sounds like it might be with yours since you say the sound goes away when the engine heats up? Not sure if this will help you but always good to check!
