OldmanPurdy wrote:A faulty MAF sensor can cause lots of problems including running rich and it very quick to check, turn off the car disconnect but don't remove the MAF then turn the car back on. The ecu will default to limp mode and the car will either do the same thing (not a problem with the MAF) or run alot better (problem with your MAF) try this then report back what happens.
Sorry for the late reply, I've been really busy the last few days.
Well I disconnected the MAF and turned the car on, the car ran for about 3-5 seconds and then just shut off.
So I'm guessing the MAF is not the problem. Next up I am going to replace the cap and rotor and see if I have any luck.
Any other advice is will be greatly appreciated.
