TDS »
https://forums.nicoclub.com/tds-u28899.html
Wed Feb 06, 2008 2:22 pm
I ended up taking out all emissions but before this, i found a leak between the throttle body and Coolant Temperature sensor. You will see three hard lines that run parallel to the intake manifold and fuel rail. They connect to 3 hoses that lead to aiv and charcoal canister. The rubber vac line to one of those lines was unplugged. Another leak was found behind the head. if you look behind your valve cover and by the firewall, you'll see two sensors attached to a bracket and tons of small vac lines looping to hardlines. I found one of those lines unplugged too.
I'm not saying you will absolutely find leaks here, but those two areas you should look over carefully because they are not easy to see.
