TurboTuli »
https://forums.nicoclub.com/turbotuli-u7884.html
Tue Oct 11, 2005 7:26 am
after concluding that my CA maf was bad(car wouldn't rev past 3k rpms), I replaced it with a ka24e maf, but now the car won't run for more than a second...if I unplug the ka maf it it runs for longer, but won't really rev...it wants to die whenever I touch the throttle with or without the maf...i've triple checked the maf wiring...
anyways, I went to talk to the local CA expert and he hadn't ever heard of a ka maf working. he said that it would work on an SR, but some CAs have 8 bit ecus(as opposed to 16 bit) and the ka maf flat out won't work. Does this sound right to anyone? I guess it would make sense, as I replaced the part that was causing the problem and the problem got worse...
I'm going to try to locate a working CA maf asap, but I'd like to confirm that this is the problem first...
