silpena »
https://forums.nicoclub.com/silpena-u34788.html
Thu Dec 20, 2007 11:07 am
mine was milled around 0.0012-0.0014. A shop tried to sell me the shim saying i needed the spacer but i never used it. I think the maxium is 0.0012 you can mill before cam position changes, but u can mill the timing cover down to match it or cut the head gasket. I don't thik u need new head bolts, you just used them. I used my oem head bolts so har 10k miles and holding up great i just torqued them a couple more foot pounds to compheshate for the strecth on them. I don't think its that big of a deal. Hmm your coolant is going somewhere....maybe ur cap is f'ed up and is losing pressure not lettting the coolant convert back to liquid from steam. Idk when i got my car back together i had a clogged radiator(tried to use that bloc seal) so i had it rodded out and then i got a new cap becuase it would over heat after 5 min of driving. I heard a crackling noise coming from it. My best advice is to examine the coolant while the cap is off and rev engine at a constant 2-3 k u should see the flow of coolant be smooth with no gunk or bubbles from the combustion gases.
