Ka24E Dies after 10-15 minutes
bham240sx1
Car: Woodworking, Car tinkering
After rebuild and setting up timing, this motor runns great for about 10 to 15 minutes. It then starts to miss and spit, and will not idle. If I hit the gas pedal even a little it will try to die. It acts like its loading up with fuel. If it does die, it will not restart until it sits for a while. The oil pressure and temp are good. I havent replaced any sensors or Injectors yet. Where would be a good place to start ? Is this a sensor somewhere or an injector issue.
McAdam
Car: I like cars and my motorcycle. boats are fun too
sounds like its a temperature sensor somewhere. it dies after it gets warmed up, but it'll start after you let it sit for a while? yup, its flooding. perhaps your cold start valve is not shutting off?
McAdam
