KA24e cam?
TopStreet240
Car: Cars! movies, books,
Hey guys, its been a while but the manifold is made! (i made it myself and it turned out nice) and the turbo is on (T3/T4 60trim) and the front mount and exhaust are on. The 550cc injectors are hooked up the the S-AFC is in the mail on its way. Now im looking at a motor build this winter and am looking for an aggressive cam. I dont want something not streetable. If you have any suggestions I would love to hear them. Thanks muchTS240
TurboKA37
any pictures?
TopStreet240
i will get them up soon, i have them on the camera at the shop, as soon as i can i will post them.
240marcuSX
Car: E34 525i
E46 M3
I would like to hear some cam suggestions as well for the E, ive been told that you dont want much overlap on a turbo application, wheres WD??
TurboKA37
nobody knows
ADAMHU
colt cams/pdm racing has several cams...i used the full race cam for several years...503 lift and 300 duration...
used it for a month or so with the turbo....does not work well...had alot of blow thru....
SingleCamSam
Shadbolt Cams in canada makes a cam specifically for turbo KA24E's. It has the same specs as the PDM stage II but has more lobe separation.
TopStreet240
is the shadbolt cam a regrind or do you just get one that they make??
SingleCamSam
It's a re-grind. Only about $200 too. Go to their website, find their # and give them a call. Very, very nice people to deal with.
TopStreet240
the reason i dont want a regrind is because the welds they make tend to fall off the cam and into the motor.
SingleCamSam
Just get a blank billet and have them grind that. Courtesy Nissan sells them i'm sure.
TopStreet240
i might just do that. Thanks
EricZ103
Car: cars, duh
So do you guys think that a colt cams/pdm racing stage II on would work good with a turbo, since it is similar with the shalbolt one? Also I know this is off topic, but while we are talking about sohc's I have heard that the ring lands go bad on them under boost. Is ther truth behind this? AT what psi do they give? And what do you have to to correct the problems, new pistons??? thanks
andrave
Car: 1989 Nissan 240SX Coupe
considering how old your KA is and how crappy the pistons are, especially for turbo use, I'd say a set of lower compression forged units with new rings would be in order...
as for cams, I'm interested too, I'm tired of jdm crap I wanna turbo my 24e.
TopStreet240
the car is old, but the motor is getting rebuilt in winter. it is also getting a high rev setup.
