Ka24de Swap.
Mystikx
Car: Nissan 240sx
Long story short.
Purchased car with solenoid malfunctioning, never got around to it ; in turn blew the engine due to over revving.
I'm far from making the big bucks, being a student succks! I got my hands on a low KM/M engine and transmission. To save some $$ and to better educate myself i'm prepared to take on this O' so daunting task of doing a swap.
But first i came here to perhaps find a guide , that search button failed on me
With that being said any , ANY help is greatly appreciated and if there is a step-by-step guide that would be amazing.
Straight swap, KA for KA
DALAZ_68
Car: 90' 240sx CA18det
what year chassis, what year engine?
Mystikx
Car: Nissan 240sx
My mistake :
My 240sx :
93' coupe SE
Donor:
93' coupe SE
( Same Specs )
Mystikx
Car: Nissan 240sx
DALAZ_68
so ur going MT to AT ? or vice versa?
Mystikx
Car: Nissan 240sx
Sticking with auto
DALAZ_68
then u dont need anything...same year engine same year car... its a straight drop it...
Mystikx
Car: Nissan 240sx
Exactly, the problem revolves around how to do it ..
DALAZ_68
disconnect ur upper and lower harnessessdisconnect any tubing like intake and P/S pumpremove nuts on engine mounts...which are 14's i believe...or 15's
remove transmission mount lift and remove
then drop the other ***** in and reverse the process...might wanna drop the driveshaft
Mystikx
Car: Nissan 240sx
You make it seem so easy .
Ill paypal you couple bucks to go into detail
DALAZ_68
thats..it lol
u follow ur upper engine harness from ur firewall all across ur car... disconnect all the plugs...then...look at ur alternator, it has a couple connections too... a plug, and a 10mm nut, ad a 8mm nut behind that one...starter has a 10mm aswell i believe. and a clip connection... and there other connections below aswell for ur transmission... disconnect them. be carefull not to break em due to age...
disconnect ur P/S pump from ur P/S lines... ur A/C, get it drained at a shop properly...specially since it's R12 FREON...****s not kew... once its drain properly... disconnect A?C lines at A/C pump... also u got 2 choices...well three for ur exaust... disconnect headers were they connect to the engine...disconnect headers were they connect to downpipe...disconnect headers were they connect to engine and drop the WHOLE exaust...which ever u find easiest...
ur gonna have ur hood off ur car BTW...
drain fruils...coolant/water/oil/... might wanna remove radiator for extra room...once transmission is loose and engine is loose pull and remove...
now reverse everything for new engine...
suggestion though...replace the timing chain and guids if u got the dough fo it...
Mystikx
Car: Nissan 240sx
Thanks for the guide , honestly tho ; you make a really indepth guide. And i'll paypal some $
DALAZ_68
Mystikx wrote:Thanks for the guide , honestly tho ; you make a really indepth guide. And i'll paypal some $
no biggie just helping someone out
if u were in near L.A. id go and help you...but this is the best i can doo
