ka24de swap start problems
silent_elite
Car: 1990 s13 with ka24de swap
so heres my story guys. car is 1990 s13 with s14 ka24de. i lined up the dizzy the way everyone says with the rotor and cap at 10 'oclock. of course i did this at tdc. i pulled plug on cylinder 1 and put a dowel rod inside and turned the crank till it was at its highest, with this being done i look at the pulley and the markings for tdc are no where close. could my timing be way off??? how can i tell if my timing is set correct???
car wont start right now either i puller the coil that runs from the ignition coil to the distributer cap and place it on the strut and when i crank it it as no spark. shld i replace the ignition coil?
Pro ViZion
Car: 1990 Nissan 240SX w/ KA24DE
I dont mean to harp man but you have 4 active threads within the past 5 days all pertaining to basically the same stuff.
You should replying in your current threads first.
Just sayin' man.
