KA24DE Head Stuff - Decked Head
deathrace2000
I was wondering how much I could get away with decking the head on my KA to acheive a mild compression bump. What CR could I acheive by doing this?
Also, are the 91-94 and 95+ heads the exact same? I was told the S14 head had a different combustion chamber design that made it more suitable for making power.
Sorry if these are retarded questions, I've already tried searching with no luck. Thanks.
j dubb
Car: guess im stuck with the s10 and dreaming about the 300zx
i dont have the answer for you but i dont think its a retarded question at all
s13rb25det
Car: 92 240sx w/rb25det
im pretty sure the heads are the same just diffent cams, also I think the pistons in the s14 are a different comp ratio than the s13 dohc kas
240ka24
make sure you deck the timing cover(head level cover). I have seen where they forgot to machine the coer and the distributor could not seat from misalignment. unless you cut off the front part of the headgasket and just use rtv.
