KA24DE Engine overheating help?
jazz4890
Car: 1991 Nissan 240sx
I have a 1991 Nissan 240sx with a KA24DE I am having a problem with my car overheating I let it idle for a while and its fine it doesnt overheat but when I am driving on the streets stoping and going it starts to overheat but when I get on the freeway and start speeding up my enigne starts to cool down very quickly does anyone know what the problem might be?
TooForOh
Car: 1992 240sx
Thermostat is stuck or blown head gasket.
CMG
Car: 1989 240sx Hatch w/ Redtop
thermostat, water pump, temp sensor...
0wn3r
Car: 1997 Nissan 240sx SE track car (SR20DET, caged)
jazz4890 wrote:I have a 1991 Nissan 240sx with a KA24DE I am having a problem with my car overheating I let it idle for a while and its fine it doesnt overheat but when I am driving on the streets stoping and going it starts to overheat but when I get on the freeway and start speeding up my enigne starts to cool down very quickly does anyone know what the problem might be?
Easiest things first, check to see where your coolant level is. If it's too low, try filling it and seeing if any leaks out. My KA had an overheating issue during idle at certain times, and it needed a coolan fill/flush.
Since it's not exactly the same situation, you may be stuck with the other suggestions.
jazz4890
thanks guys for the information I will try seeing if the thermostat is broken and I will check my radiator to make sure nothing is cracked or leaking.
WWJD
also take a look at your oil. If it's milkie head gasket
jazz4890
no its not the head gasket there is no milklyness to the oil and there is no white smoke coming from my exhaust thats the first thing I checked I think/hope its just a radiator type heating problem.
