KA24DE Cam upgrade?
RedDario
Car: duh, my car
I want to know how easy it is to get my cam upgraded. I read that you can send your stock cams away to be shaved and shaped, but wouldn't the cam work better if the lobe is bigger, so there is more time for the valves to be open? If not, does anybody know where to get performance cams for the KA24DE?
Exar-Kun
Car: 2005 350Z
RedDario
Car: duh, my car
Thanks, but that doesn't explain how shaving a lobe would make more power. Also, what "core" are they talking about?
C-Kwik
What they do is remove material around the base of the cam(the parts where the rocker arm makes contact when the valve is closed. This makes the difference from the base to the top of the cam lobe bigger. Then you adjust the shim to compensate for the additinal valve lash. It gets a bit more complicated in actuality as the lobe itself may be modified some too, but this is essentially how they make a higher lift cam out of an oem cam. JWT also sells cams, but they use fresh billets so the base diameter is OEM spec. But they are fairly pricey.
Mayhem_J30
Car: Ummm...My Car
search for 'camshaft' at http://www.howstuffworks.com give a good explanation.
