StryfeS13 »
https://forums.nicoclub.com/stryfes13-u150110.html
Wed Feb 23, 2011 12:39 am
Make sure your TPS is adjusted correctly. Unplug your TPS and see if it still bogs. An unadjusted or incorrectly adjusted TPS will cause the car to idle high, and/or bog.
To test your TPS voltage, backprobe the middle wire of your tps connector with a volt meter, and touch the other probe to ground (valve cover bolt works) It should read .50, if it doesn't, adjust it till it does.
High idle could also be because the throttle plate screw is holding the throttle open. I don't know why people screw with that when they still have the IACV on there car, if the throttle plate screw is adjusted at all, re-adjust it until it is not holding the throttle open whatsoever. I had that issue once.
Also, try a tune-up. Change spark plugs, wires, oil, etc. Check grounds also.
