KA-T with a T25
MikeMurphy
Car: Guess
Has anyone actually done this? A couple days back I remember reading someones post who made it sound like he did, but I couldnt PM him:mad: .
Anyhow, if you have run this, pls post a little something.
Nathan
It's allready a small turbo for an SR...I can't imagine one on a KA! I guess it'd spool up fast though, but then give out up top :(
MikeMurphy
Car: Guess
Yes, I know that and other major hurdles. Thanks for your reply.
andrave
Car: 1989 Nissan 240SX Coupe
I have heard even a straight up T3 is too small for the 2.4 liter KA, so I can't imagine a small T25. Now the T28 variants off the later silvias, I would think, would be able to support a modest psi to redline and they would spool up immediatly, which could be interesting. But ultimately the tiny turbine housing is gonna reduce your volumetric efficiency and choke the engine off, and with as much exhaust as a 2.4 liter flows I would think boost creep would be an issue with the smaller T28's tiny internal wastegate.
I like the body kit on that car, mike murphy, not the wing, but the kit is pimp.
MikeMurphy
Car: Guess
Thanksfor your thoughts. I know it wouldnt be properly sized. I have done lots of research on this. Just looking to know if someone has DONE it.
Nathan
Do you allready have it or something?
andrave
You know, I did see a guy with a custom manifold for twin T25's once... everyone knocked him of course but I still think that sounds interesting! If you go for the twins off a skyline they would be matched pretty well for the application, I'd think. Just a thought, anyway....
MikeMurphy
Car: Guess
well i dont think anyone has done it.
yeah twin T25s would be such a complete mess of piping and troubleshooting!
andrave
not too much of a mess in piping... do a single blow through Z32 mafs, and Y the two turbo outputs together before the intercooler. give each turbo its own little filter, bingo.
DriFt3r
Car: Racing and Drifting
I've got a T25 water cooled turbo. I love the torque but top end sucks. Boosting 6psi on stock motor.
MikeMurphy
Car: Guess
Your running a T25 with the stock turbine on your KA? pls confirm.
andrave
please note that there are several variants of T25 running around... one off a skyline wouldn't work, tiny turbine. ca18det is teeny too. sr might...
DriFt3r
Yes I am running a Garrett T-25 turbo on a log style manifold. Like I've said between 2k-5k you get really good power but after that the power just flat lines. Heres my dyno results for 4 lbs of boost. http://caleb.itgo.com/sptest.gif Remember that is is on a stock motor with no tune-up of any kind and stock fuel trim. The numbers are kinda low but they are good for the time being. Let me know what you guys think.
andrave
which T25 is that?
MikeMurphy
Car: Guess
Do you know what A:F your running? Do you have a boost gauge and if so does it hold 4psi to 6000rpm?
also, do you have msn or icq?
RiceNWater
Car: CARS
Hmm... only a torque increase at 3-5 RPM? Not too bad for 4psi, but I'm kinda wonderng what kind of damage the turbo will have if you push it any harder.
andrave
looks like power and torque were above stock the whole dyno graph to me, rice.
DriFt3r
I have no idea what the a/r is...but right now I am boosting about 6psi. Have been doing this for awhile and YES it holds boost all the way to redline. I tried boosting 7 psi but then the engine started to run lean so I turned it down to 6 just to be on the safer side. I know you guys are gonna Flame me for running this amount of psi on a stock motor but I have done this for awhile now and I take it up to redline every weekend and the motor still has great compression.
SloS13
DriFt3r wrote:I tried boosting 7 psi but then the engine started to run lean so I turned it down to 6 just to be on the safer side.
:flamer
240_2NR
Car: DayDreaming
Drift3r what kind of T25 is that? and how much did u do to get it to work? i just want like 7psi daily, maybe 10psi when racing, so i wanted to know what u did, i wanted to know if a T25 from a 2nd gen eclipse would work i might be gettin one with i/c and was curious if any one has any info please help, I have a 93 240
240_2NR
Car: DayDreaming
Drift3r what r u using to keep it at 6psi think ill just run that maybe manual boost controler? whatever, i like the idea and really just want a little boost untill i get out of college i wont race it untill when get a nsport kit or WD's kit dont know have to wait and see if anyone else has a ghetto-rigged t25 plz respond im cuirous i know some of u are goin to say wait untill then but i can not wait and just want a litte more umph
tapdeznutz
i'd like to see about the t-25 also.
MikeMurphy
Car: Guess
i have the dyno of a t25 running 4psi. Its pretty ugly. Gain of maybe 20 hp and tq throughout the band.
interesting though.
talk about reviving topics from the dead
tapdeznutz
why would a T28 be too small? the SRT-4 runs that turbo and its a 2.4 liter also. and SCC magizine dynoed it at like 230 or 250 something like that.
MikeMurphy
Car: Guess
if i recall correctly the t25 uses the same size turbine as the t28. t28 just has a larger compressor on it. dont quote me though.
everything suffers when the turbine isnt properly matched to its application.
240_2NR
Car: DayDreaming
yeah the 20hp gain is pretty stupid i already have a DSM t25 and i/c so im goin to find me a second dsm t25and have a twin set up i know a guy who will make me the manifold, down pipe and y-pipes to and from turbo, need cash to do it but im definitly goin to try it, just give me some time, ill let ya'll know what happens, it'll be a while but i will try it
240_2NR
Car: DayDreaming
if i can change the t25's to t28's cheaply i might try that, well have to wait and see..
240_2NR
Car: DayDreaming
do u think that the twin t25's or twin t28's would be a good idea not really for alot of power because only two exhaust puses is pushing the turbo but i think the pressure of the ehaust will give a moderate amount of power, looks cool too
240_2NR
Car: DayDreaming
what i meant is the exhaust pressure will still move it, just not as powerful as four exhaust pulses
240_2NR
Car: DayDreaming
i know the newer SR20's have the t28's and the neon srt-4 but what else does?
