Try slowing down, typing clear words and using grammar.taco_401 wrote:i would builted my own kit before buying some one els kit
What makes you say that? Do you have the JGS kit? Do you have a boosted KA? Is 450whp not enough? Because that's what the JGS kit is rated for...silvias14freak wrote:Jgs kit is a decent start but trust me you'll upgrade in a little
Yep, it's a great combo.Kwon88 wrote:By the way does that sound like a decent set-up I put together? ^^
i second on emance, work the same and gaurantee to work or if you have any problem, jason(emance) wont stop until you're happy w/ your tune.WDRacing wrote:Listen to the advice you've already gotten...it's solid. I've read some of racersonly comments and most are just bad...
Try Emance over JWT or Enthalpy...they are only $150 and do exactly the same thing.
WD
Perfect? Really???racersonly2004 wrote:the setup i gave u is purfect
Would you mind showing a Stillen ECU tune for the 240SX?EGT Sensor on the 4th runner? Are you talking about the EGR valve that aft of the intake mani?Exhaust header for the T28 is the bottom mount type with NO external wastegate flange. The top mount type with the flange for the wastegate doesn't come in a T2 flange for the T28...so yeah...no idea what you're talking about You're talking about doing things cheaply and using EBay parts, yet you're telling him to upgrade valve springs, cams and cam gears when the stock parts are good for 450whp.And last but not least, the $595 JWT tune over a $150 Emance Tune...racersonly2004 wrote:couldnt have said it beter myself but i heard stillin also has pretty good tunes. but back to the turbo kit if your gona go for hp around 250-300 at the flywheel and if ur trying to save some cash u could piece a kit together for under 2 grand using ebay turbo headers about $80 (just block off the egt censor on the #4 runer) ebay intercooler about $100 ebay oil supply about $30 sr20 injectors about $25 each used. rebuilt gt28 from s15 about $300 (save an extra $100-$200 by blocking of the wastegate flange and using the internal wg on the gt28), custom 3" downpipe and exhaust about $300. total about $910+tx and shipping. all thats left is the jwt ecu $595 if u go wich the stage 3 cams from bc with the dual valve springs for about $600 ull be able to increace ur redline about a 1000rpm then get jwt adjustable cam gears $140 to spread the lobes apart which will make it idle smoother and prevent exhaust gases from re entering the combustion chamber. on about 7-10 psi and the stock 9.5:1 compression pistons u should be able to break the 300hp barier on pump gas and all for under $2000Modified by racersonly2004 at 12:55 AM 7/12/2008
OWNEDD!!!!!!!!!!! LMAO!!!!!! :hideWDRacing wrote:
Perfect? Really???
So I meant what I said...you have no idea what you're talking about and are giving people not just bad advice, but you're mixing parts that don't even work together.
WD
